GOT A 1995 XP. I SET THE IDLE IN THE WATER AT 1100. WILL IDLE ALL DAY AT THIS RPM IN THE WATER. AFTER RIDING PULL IT OUT OF THE WATER ON THE TRAILER AND IT IDLES AT 3000 WILL NOT DROP BACK TO 1100. I SET IT AT 1100 ON THE TRAILER AND IT WILL DIE AT IDLE IN THE WATER. CANT FIGURE IT OUT. MOTOR RUNS PERFECT ON THE WATER. ANY SUGGESTIONS?
SEADOO IDLE PROBLEM
1500 in, 3000 out is the norm. If you had lower rpms out your carbs were probably mistuned and running a bit richer than they could have been.SBT Tech Support is here to help with your problems.
