i got a 94 XP 650. took it out today brand new engine. and im curious to know what are some of the symptoms of a bad wear ring other that cavitaion. is heavy vibration one of them? i give it gas and RPMs come up and dont go no wear and theres a nasty vibration. took drive line apart tonight and splines are ok on PTO, impeller, and shaft. thanks guys your the best.
94 XP drive line prob
Sometimes it is very easy to look at the impellor or pto and think the splines are good. But, upon further inspection, using a bright flashlight, you will notive the splines that are back about 1 inch into the pto or impellor are completely stripped out allowing the shaft to spin in either one.Bill O'Neal WCM
