Factory Seadoo manual says use to use 242 loctite on lower part of studs that go into upper crankcase and torque to some minimal value. Where I am confused is on the upper part of the studs and head bolts themselves. I believe the manual says to use grease on the threads and loctite under the bolt head. Is this a mistake in the manual? It would seem you would use loctite on the threads and grease under the bolt head.
951 head bolt/stud loctite?
