I have a 1999 sea doo speedster with mikuni bn 38 dual carb set up. The forward carb has all the fuel intake and return primary connections, then interconnects to the rear carb. The fuel return fitting is a plastic Tee. Unfortunately, while taking the return line off, the nipple broke off in the hose. I'm having a little trouble identifying this part in any of the service manuals. My questions are: what is the part no.?, how do you remove it and install the new one, is there a metal substitute? I'm thinking of removing the plastic fitting, threading the hole for a standard fuel tee fitting as a last resort. This must be a common occurrence.
Thanks for any assistance.
