is there anyway to check the stator
  • is there anyway to check the stator
    on my 96 GSX that keeps blowing the 15 amp fuse, is there anyway to check the stator, and if so how would you do it? the easiest way possible. thannks ryannull
    Youll need a ohm meter. Also youll probably need a shop amnual to get the values. All the hook ups will be in the gray electrical box
    Rob
