What should I do with my Cylinder Head on my 96 XP? Should I have it modified or should I replace it, nothing is wrong with it, I am just looking for a higher compression ratio. I want to keep my craft Limited. I also want to run 93 or 94 octane, I don't want to mix race fuel. I mostly ride for recreation. Thanks
Cylinder Head on 96 XP
A milled oem head is a good choice too. With any head, keep the pumping pressure down to a maximum of 175 lbs, with at least .042 squish clearances. As our pump fuels are not as good as they used to be, you would risk having a detonation problem if you follow the meathods used in the past when the pump fuels were of better quality.Bill O'Neal WCM
Send your head and carbs out to PPG,and get the level one kit done they will mill and redesign your head and rejet your carbs for you , all for under 500 bucks , this set up will be better than any aftermarket product, and PPG is the best there is when it comes to SEADOO PERFORMANCE, go to there web page to check them out www.seadoo.net. They also will back there stuff up 100% and have excellent tech support .You will not regret doing this if you want the best
