All external torque values are indicated in the appropriate Installation guides, found in our Technical section. On a Sea-Doo 800, they need to be at 16 ft. lbs. - and don't forget the Loctite!
Zoobydoo,
To the best of my recolection, the torque for the carb bolts is 15ft/lbs. Always torque carbs bolts or nuts evenly to prevent warping the carb bases.
Bill O'Neal WCM
