Whats the best octain to run
  • Whats the best octain to run
    I installed a PPG level 1 kit on my 96XP,Whats the best octain rating to run in this ski now.I know i will probally need to run premium pump gas but premium varies from 91 octain all the way to 94 octain. Which one will be the best for my ski.
    Do a compression check first and find out actually how much your compression was bumped. If it's say 165 psi cold, then 91 should cover it.
      Most of the time when tuners specify 'premium', they mean 91+. This can vary however, with the additional variable of oxygenated fuels in northern climates durring the winter months, methanol additives and altitude. It's always best to consult your tuner and let them know where you live, what altitude you ski at, what your mods are and they can answer specifically.
      [ February 24, 2001: Message edited by: Bryan Glynn - SBT Webmaster ]
        If it's ethanol, then move one level of octane up to be safe.
