I have a 97 785 SD,that i'm having the stock
carbs reworked to 42mm. I am planing to match
the intake opening to the carb base,so to do
this i'ved removed the intake and also the
oil inj. nozzles by applying some heat and
using visegrips to pull them.Will the check
balls be damaged by this heat? Do you sell
new nozzles or know who would? Also for
future reference, whats the cost of a trued
and welded crank?...Thanks
