951 MOTOR HELP !
  • 951 MOTOR HELP !
    I'AM TRY TO REMOVE THE CYLINDER BLOCK OFF MY 951 MOTOR FOR A REBORE.I HAVE RMOVED THE HEAD BOLTS,NUTS AND STUDS BUT IT WON'T BUDGE. HAVE I MISSED SOMETHING ?. ANY HELP WOULD BE GREATLY APPRECIATED.
    You need to use a large rubber mallet! It's going to be tight!
      You didn't say if it is in the hull or not. If it is in an XPL hull, you will need to remove the studs, as the clyinder will not come up high enough to clear the studs.
      There are two locating pins between the clyinder and the case. The clyinder must come straight up to get off of the pins.
      Bill O'Neal WCM
        THANKS BRYAN & BILL I WILL GIVE IT A GO.
          BINGO ! GOT THE SUCKER OFF. THANKS MATE
