Flame Pattern
  • Flame Pattern
    I have a 96 GTI fitted with a F/P and would like to know what a good flame pattern is mine goes to the edges in some places and not in other places is this normal I have EGT fitted aswell to keep a eye on things
    thanks Craig
    ps Im from Australia :
    Joe St. Louis will be able to give you a good answer to that question when he returns from doing a boat show, on Tuesday morning.
      GTI
      From what you described, it sounds like a normal burn pattern on the piston. If you notice the clear spots should be lined up with your transfer ports. As the fuel comes in it tends to clean off the piston in that area ;)
        Thanks for the Information Joe
        Craig
