Fuel Line replacement
  • Fuel Line replacement
    Anybody know what the diameter is of the gray fuel line that should be replaced? Inner Diameter and Outer Diameter?
    Also, isn't there one line that's slightly larger in diameter than all the other lines?
    - Craig<br /><br />'04 Baja 342<br />'04 GTX SC<br />'98 GTXL<br />'95 750 ZXI
    The fuel line is 6mm and the return line is 8mm. Most autoparts stores carry hoses that have inch and metric sizes written on them. Pick the two closest.
      What would you say - about 20 Feet of the 6mm fuel line and about 6 feet of the 8mm? I don't want to make 2 trips, but don't want to have too much left over.
        20ft how many skis you doing
        <a href="http://www.leximotorsports.com" target="_blank">www.leximotorsports.com</a><br />606 TEAM LEXIMOTORSPORTS<br /> <br /><br />2004 RXP
          Actually on limiteds, the fuel feed ("on" lines) are 8mm, and the return lines are 6mm. Not the other way around as stated above.
          You need about 10-12 feet of 8mm, and about 4 feet of 6mm.
          I use 1/4 " automotive fuel line for the 6mm lines and 5/16th " automotive fuel line for the 8mm lines. You can buy it at any auto parts store, much cheaper than the crap SD sells.
          Bill O'Neal WCM
