Results 1 to 3 of 3
    21,545
    Post
    This is what happens when you don't use the recommended oil in your ski.
    This Sea-Doo 951 DI needed the high synthetic but didn't receive it. Instead it has a thick carbon deposit layer on the valve edge and a huge slimey, gooey, valve-slowing layer of oil sludge all over it in a very short time.
    [ February 10, 2003, 10:37 AM: Message edited by: Technical Support ]
    Jul 2002
    Bismarck, ND
    310
    Post
    thats what mine look like when i use di oil, accually worse, the stuff is like molasis, as soon as i run out of my di oil i am using amsoil, i have been using in my other seadoo and in both snowmobile, and the valves never need cleaning.
    21,545
    Post
    The XPSII (replaced the DI oil) is supposed to be much better for that. Make sure your oil pump is correctly adjusted also - you shouldn't have that much buildup under normal circumstances.
  1. Correct 2-cycle oil
    By MTG in forum Sea-Doo
    Last Post: 06-01-2008, 09:23 AM
  2. 97 xp
    By new XPer in forum Sea-Doo
    Last Post: 10-03-2007, 07:20 PM
  3. Oil Change, Yamaha 4 Stroke Skis
    Last Post: 09-09-2005, 03:27 PM
  4. Correct oil ratio
    By braap in forum Sea-Doo
    Last Post: 08-22-2005, 12:18 PM
  5. Replies: 2
    Last Post: 08-10-2005, 12:37 PM
