float/fuel gage snding unt
  • float/fuel gage snding unt
    Is it possible for that float to become saturated and not "float" anymore? I took the whole assembly out, then connected it back to the harness, rocked it back and forth to move the float, and the gage worked fine. back in the tank & it always registers empty. Can that float be purchased separately?
    96gtx
    Yes, you can buy the float assy seperately.
      I HAVE A SIMILAR PROBLEM. GET THIS -- TWO (2) 2003 SEA-DOO GTI'S -- BOTH HAVE GAS GAUGE PROBLEMS. THEY BOTH NEVER READ OVER 1/2 TANK EVEN WHEN FULL.
      THE LOCAL FIXIT-GUY SAYS 250.00 EA/500.00 BOTH TO REPLACE SENDER UNIT.
      ANY SUGGESTIONS? I HATE HAVING TO ID FUEL LEVEL BY SEAT REMOVAL.
        Greg,
        The part sells for about $120.. at Sea Doo and you need a screwdriver to replace it.
        Do you think $250 per boat might be a little on the high side? I do.
        Why not DIY?
          I agree Bill -- it's way too high.
          I am a rank amateur with regard to pwc repair. Is this an easy fix?
            Very easy fix if you remove the lower portion of the glove box.
              Thanks, I'll give it a shot!
              BTW, Any lead on Biggest discount sea-Doo Parts dealer?
                Try www.parkeryamaha.com
