fuel baffle testing possible?
  • fuel baffle testing possible?
    Is there any way to test the fuel baffle to see if it is actually sending a signal? Mine worked yesterday and didn't today, go figure. I have checked all connections.
    [ June 25, 2004, 09:27 AM: Message edited by: *97GTX* ]
    Unhook the plug that comes from the pickup to the mpem. Jump across the connector (side that goes to the mpem) and the guage should read full. If it does it's the pickup which needs replaced.
    Dick Bell
    http://www.hansenskidoo.com
      Thanks!
        thanks for the tip, I had a bad fuel pick up baffle.
          if you take it out you can fix it as long as you have the patience to do it, it is easy to fix it, difficult to take it out and get the black stuff out
