In my seadoo manual it says that seadoo only offer a .25mm oversize piston because of clearance problems with the rave valve, I know SBT only goes up to 1mm oversize.
My engine is .5mm oversize, and I am trying to find out what the recomended clearance is if you put a straight edge over the exhaust port and measure the rave valve clearance with a feeler gauge.
I know the engine was running previously with these pistons, they dont appear to be hitting, I just want to be sure that the clearance is correct, due to the fact that the rebuild has already cost me FAR too much, so I want to avoid any possible catastrophies (?).
Thanks, from Downunder!!! :D
