Hey Crew
When you put a 800SD crank in the cases do you seal the inner crank seals in the cases, ie: put some crankcase sealant in the locating grooves where the inner crank seals sit??
The reason why: to help eliminate air/oil leaking into the cylinders from the rotary valve shaft area.
Thanks... :D
Thanks... :D
