Results 1 to 10 of 10
    Mar 2002
    Geelong, Australia, Near
    272
    Post
    G'day From Downunder Again
    Was just wondering whats the difference between reed valves and the rotary valve. I understand that reeds open from crankcase suction and suck thru fuel and air, and the rotary valve works just like a gate, as it spins around. Is one system better than the other? I thought rotary (800cc) must of been better, but then seadoo went back to reeds for the 951cc. I was told some motor bikes also use a rotary valve. Whats the theory of the difference's between both systems? And which is the better system?
    If reeds are better would it be possible to remove the rotary valve and adapt reeds over the ports? Would it run better, the same or worse? You could always remove the rotary valve shaft.
    I wouldnt do this, but am just curious to understand why they changed, and which is better.
    Thanks Guys
    - From DownUnder
    Feb 2001
    Clearwater, FL
    7,358
    Post
    No, it's not possible to convert.
    A rotary system is more efficient and can control the intake charge better than reeds.
    Sea-Doo had to go to reeds on the 951 simply because the rotary valve and surface would have needed to be too large to fit on the case for the size of the engine. The 800 is about the physical limit of it's use.
    That being said, I'll take reeds over a rotary and it's associated extra moving parts, extra seals and extra problems - ANYDAY...like Delta 2's or M-16's [img]smile.gif[/img]
    Feb 2001
    Glendora, Ca.
    5,204
    Post
    BUZZZT ! Wrong answer.
    I have a reed adapter for a rotary valve motor. Tried in back in 1994 on a 657X race boat. Didn't make any improvements, so I ditched it. R&D actually had them in their catalog at one time.
    Bill O'Neal WCM
    Feb 2001
    Clearwater, FL
    7,358
    Post
    LOL! [img]graemlins/spit.gif[/img]
    You get some weird stuff Bill [img]smile.gif[/img]
    Oct 2001
    Georgian Bay, Ontario, Canada
    75
    Post
    Michael, Rotax rotary valve engines were designed for SKI-DOO, not Sea-Doo. In the old days reeds were steel and they were completely sh*t in sub-zero temperatures so companies were stuck with piston port induction on snowmobiles.
    Rotax comes along with the rotary valve for their sleds and it was brilliant. Worked great in sub-zero temps. It was great for the time. All the high output ROTAX sled engines use reeds now.
    In the 90's, if you watched what Rotax put into their sled engines, then you could pretty well guess what might come into their ski lineup a year or so later. Rotax sled engines rev about 1000 rpm faster than their ski engines but are generally much smaller in displacement. Ski-doo produced a 800cc reed induction twin lately, but it blows up more than their other twins.
    I like reeds over the rotary valve in skis for the reasons Bryan has already stated.
    97 GP1200/99 XPL<br />Head, intake and handling mods on both
    Jul 2001
    tejas
    534
    Post
    the better the performance, the more maintnance. my sea doo racing manual says/show several different ways in which the rotary valve outperforms reeds. but like brian said, it's nice but has more moving parts/things to wear out. in other words, future problems. :(
    cameron "da river rat"<br />3x pro runabout 720 engine blower!<br />(jetskianist~adictionist~modificationist)
    Feb 2001
    Tx
    38
    Post
    Hey Bill, does that reed adapter fit all the upright motors? If you still have it around, I might be interested. Maybe I could get George to help me redesign the intake tract so it might perform beter....ROTFLMAO [img]/graemlins/cwm27.gif[/img] What type of reed assemblies does it use?
  8. #8
    Feb 2001
    Glendora, Ca.
    5,204
    Post
    Yes I have it. It uses 650 Kawasaki type reeds and cages. The one I have has aftermarket Boyseens Rad valve reeds in it. It fits 580-720 engines. It even has an R&D intake manifold on it. It may even have a st of blue 42mm taper bored Racing Kehins on it, all set up and ready to go. I'll have to look. I haven't seen it in awhile, but I know where it is.
    How does $200 complete sound ?
    Bill O'Neal WCM
  9. #9
    May 2005
    Detroit City
    1
    Default Re: Rotary Valve Vs. Reeds
    Bill if you still have this set up I will take it off of your hands.
    Ben
  10. #10
    Nov 2003
    Glendora, CA
    6,846
    Call me at 626 914 9509.
  1. 580 Engine Rotary Valve & Gear
    By kscycler in forum Sea-Doo
    Last Post: 03-23-2021, 06:28 PM
  2. 90 SP Rotary valve position
    By vtdanokim in forum Sea-Doo
    Last Post: 06-08-2006, 11:15 AM
  3. Seadoo Rotary Valve damage - Advice needed
    By jdpowerski in forum Sea-Doo
    Last Post: 09-17-2005, 11:14 AM
  4. Rotary valve questions for a 787RFI and premix
    By RICHRICH36 in forum Sea-Doo
    Last Post: 09-14-2005, 07:57 PM
  5. Rotary Valve cover - damage or normal?
    By seasoned in forum Sea-Doo
    Last Post: 12-02-2002, 01:03 PM
