Correct Water Temp 95 Seadoo?
  • Correct Water Temp 95 Seadoo?
    Thanks for the answer. Even though I have water flow, is there a way to determine sufficent water flow is there and what the water temp should be? Where would you get the temp reading on the PWC? The visible water flow valve on the rear behind the ski attachment?
    [ August 18, 2003, 09:58 PM: Message edited by: WTW4UA ]
    There isn't any standard, but if you have a strong stream, and it's around 180 deg., it's fine.
