Results 1 to 8 of 8
    Jun 2003
    6
    Post
    I have been hearing an intermittent knocking noise comming from the engine. I had a compression test done and the results indicated 144 psi. It starts easy, runs well at low and high rpm and is not suffering from any power loss. Mixed input indicate piston or rod issues. Any suggestions? I am mechanically orientated, but have never worked on a PWC engine. With the right tools and manual, is this something I could open up and check or does it need a dealer mechanic?
    21,545
    Post
    How many hours, any mods, did it start suddenly and under what conditions do you hear it?
    Jun 2003
    6
    Post
    AT idle speed it is most distinct. there is 53 hours on the clock, no modifications that I know of and it appears that it has been flipped before, and opened up. It is a 01 RX, which I have only used about 3hours.
    21,545
    Post
    Well if it's definitely knocking from the block, I would pull it now for inspection or you could be looking at over a grand extra later if your rod goes through your case or other parts.
    Feb 2001
    Sacramento, CA
    70
    Post
    Piston Slap? Don't wait till goes all the way out or TS is right and it will cost much more.
    Get one of those stethoscopes with the rod on the end and try to pinpoint where it's oming from.
    I intend to live forever - So far, so good.
    Jun 2003
    6
    Post
    The rest of my original posting, can this be done by a novice like myself. Could I visually pick up a problem with the rods or piston if there was one, or should I just take it to a dealer
    21,545
    Post
    I would take it in to be safe, if you are very new. At least get a service
    manual if you want to try.
  8. #8
    Jan 2002
    Morgan city La.
    323
    Post
    Find someone in your area who knows about seadoo enagines and can look at it for you. It may save you time waiting at the local dealer. I think the 3 dealers here are telling people like 4 or 5 weeks before they will even look at something.
  1. 587 connection to engine support bracket
    By SC93SPI in forum Sea-Doo
    Last Post: 06-12-2021, 11:44 AM
  2. Understanding the 951 DI/DI-LE
    Last Post: 01-23-2008, 08:42 AM
  3. Purchase of used 951 engine
    By Roldanw in forum Sea-Doo
    Last Post: 10-26-2007, 02:09 AM
  4. Rebuilt 951 Engine Vibration
    By gxrchk in forum Sea-Doo
    Last Post: 05-23-2007, 05:47 PM
  5. 951 engine light
    By ermess in forum Sea-Doo
    Last Post: 06-15-2006, 05:41 PM
