Is the water injestion problems on the 97-99 951 (GSXL for example) only a issue if you are getting water in the engine compartment? or does it have somthing to do with the way the water is routed internally. I have the diaper on my motor, and the rubber flaps over my carbs. But i was reading somthing about chaging the exhaust gasket and all kinds of other stuff also. But I never get so much as a drip of water in my engine compartment .. so if that is the only way this problem occurs I will not worry any more about it.
Thanks,
Robert
Thanks,
Robert
