Results 1 to 3 of 3
    Jul 2001
    Missouri
    17
    Default
    What's the simplest procedure to remove&replace reeds on 750 Fugi? I haven't figured out how to remove top & inner bolts on reed block assembly yet. Am trying to not remove carb's, Is it possible?
    Feb 2001
    Clearwater, FL
    7,358
    Default
    You must remove the carbs.
    Feb 2001
    Westminster California
    553
    Default
    no you have to remove carbs. My 750 SL was a pain. Remove the carbs as a unit and use new gaskets. Polairs skis are really temperamental if the carbs get misaligned. there is a bracket on the carb bodyes that holds all the carbs together. i dotn knwo if they are on the new ones but I knwo on my 93 they were on. and it specifiacallysaid not to remove it and if you do the carbs have to be realigned.
    its a pain, but what reeds are you installing. Personally I dont see any advantages by replacing reeds. the aftermarket reeds dont last as long as stock ones. unless you have stainless steel reeds ( you shouldnt) or the stock ones are going bad i wouldnt bother with other reeds. the only ones I would recomend are v force but they wont make a differnece on a stock ski
    Rob
  1. 94 Polaris 750 SLT Carb Search
    By dwg5399 in forum Polaris
    Last Post: 08-09-2009, 08:28 PM
  2. Polaris is OUT of the PWC business!
    By Technical Support in forum Polaris
    Last Post: 09-02-2004, 11:56 AM
  3. POLARIS 2003 models - hot of the press
    By Airborne in forum Polaris
    Last Post: 08-01-2002, 01:12 AM
