carb settings 95 slt750
  • carb settings 95 slt750
    Hi,, I finally got this thing running, and would like the proper carb settings, i have seen settings posted here for the 780, but not sure if they are the same, thanks for your help!
    High-speed screws: 7/8th turn out #1, 3/4 #2, 1-1/8th #3.
    Low-speed screws: 1/2 turn out.
      Just recently got into the jetski fun a few weeks ago and have had to repair my SL750.
      My question is: How do you turn the hi speed mixture screws that far when it only allows a 1/4 turn changes. How do you screw it all the way in and then unscrew it the correct number of times? The clymer manual I have wasn't very descriptive on this. Thanx! And what a great board this is!! Just found it today...
      94 Polaris SL750<br />96 Tigershark Montego<br />99 Mustang GT Coupe<br />00 Mustang GT Conv.
        You have what are called 'limiter caps'. They are just plastic caps that slide over the screw head. Just pull them off before adjusting.
