Fuel Pump Replacement
  • #31
    The Skat 12-17 or a 17-22? You probably have the 12-17, which is perfect. That's what I am using. You would not even be able to run the ski on a 17-22.
    • #32
      I believe the 780 has different cooling passages on the jugs, etc. that help. [shrug]
      I should have parts off to have the stock heads modded and porting work done before the end of this week.
      I'm running the skat-trak 17 swirl [off the top of my head]
      -Skexies
      • #33
        sorry, my bad... too many numbers in my head..
        I'm running the scat-trak 13/18 swirl and the 6 vane stainless stator.
        • #34
          It should be fine with the 13/18 but you might have to repitch it to a 12/18 or 12/17 or bore your stock nozzle 2 mm? The SL750 will react a little different to the dry pipe than the SLX780 so I can't say for sure.
