Twin 700 said:
Please Please go to this site http://www.ngksparkplugs.com/techinf...s/techtips.asp
Read through the tech info.
I have observed much more damage to spark plug threads caused by folks who are "afraid of stripping the threads" than by people who use "gorilla-like strength" to tighten them.
Think about this; If the plug is not tight enough, it can move up and down in the threads in the cylinder head, as this occurs, the spark plug will act like a file and very quickly cut through the aluminum threads in the cylinder head, causing exactly the problem that you are afraid of creating.
Your engine's proper performance depends on the plugs being tightened properly; in your case, 18 ft-lbs of torque which will properly seal the plug gasket, and secure the threads together. This will ensure the correct heat dissipation properties of the plug.
The firing ends seem to look well within the acceptable range for a good running engine, and I am willing to say that the color will improve some more, once you torque the spark plugs properly.
[ April 15, 2002, 07:57 AM: Message edited by: John Kubiak ]
also I hope I am tightening the plugs onto the top end properly.. I put after the plugs are snuged... I used to turn it about 5-15lbs of torque... not much,... but engough to know that I wont strip the threads in the block itself where the plugs go.
