Boggin prob....maybe.....
  • #31
    Originally posted by John Kubiak:
    "Snug" plus a 1/4 turn, leaves a lot of room for loose plugs. If you check the box that the plug comes in, NGK recommends finger tight until the gasket touches the head, and then 1/2 to 3/4 of a turn from there. It ususally results in 18 to 20 ft-lbs of torque, fairly consistently with new plugs. As used plugs' crush washer gaskets have been crushed before they will require slightly more torque.
    As for the screwdriver, try this link, and scroll down towards the bottom the item number is 08-119 http://www.motionpro.com/servicetools_2.html
    John, Thanks I just placed an order today for that screw driver. It should be here tomorrow. :D :D :D :D
    Also will be taking it out Friday to test ride it with correct plugs and correct torque to the topend (motor).
