94 sl750 with SBT motor and added fuel pump plumbed in as SBT recommends. Question on the adjustment of the idle mixture screws....the stock baseline setting has the #1 cylinder turned out greater than the #2 and #2 greater than #3. Is this because of the lone fuel pump used? Will the added pump change these settings due to increase in fuel flow? If I choose to add a third pump will this affect the settings even more?
Any help is appreciated.
