Battery was a little low the other day so I hooked up the maintainer (have this hard wired in so I can just hook up w/o taking battery out each time).
Charged a little while, then decided to go ahead and take battery out to check water, was about 1/2 inch low in each cell. Put distilled water in to the level marks.
Put battery back in, charged some more, then went to the lake. MFD displays 18-19 volts now, while off and while running. Any ideas what's going on here? I was going to try disconnecting the battery and letting it sit then reconnect to see what happens. All other functions of MFD are operating correctly, and boat is running fine.
Thanks - ShowMe
Thanks - ShowMe
