Results 1 to 3 of 3
    May 2003
    MD
    3
    Post
    I posted earlier describing problem starting a 1995 650SL. Tried seeing if there was any spark. I did not see any. At this point should I just replace the kill switch? Is there any trouble shooting I can do to bypass the kill switch in order to be sure it is inop before buying a new one? Or, is it inexpensive enough that it would be a good idea to replace it just to eliminate it as a possible problem? Where is the best parts source to order it from? Finally, what is the component that sits under the handle bar pad on top of and centered on the handle bar? Is it part of the kill switch? Thanks again for all the help!
    Jeff
    Sep 2001
    CO
    328
    Post
    If you have tried most everything else, then I would replace the switch.
    www.partsland.com is a pretty good source for parts.
    May 2002
    Minnatonka,Mn
    168
    Post
    I can almost guerentee that is not the kill switch. take thing apart, then unscrew the rubber cover of the switch. If water has gotten in there it will be super corroded. If it is clean and dry I would go over all the wiring and open up the box for any loose connections. If you find nothing it is problebly a stator or coil prob.
    97 SPX built to go fast, and jump...What YOU got?
  1. 93 SPi stop switch
    By SC93SPI in forum Sea-Doo
    Last Post: 10-30-2007, 07:59 AM
  2. Replies: 0
    Last Post: 08-31-2005, 09:45 PM
  3. kill/lanyard switch problems
    By Venom in forum Yamaha
    Last Post: 07-03-2005, 04:45 PM
