I have a 95 780. I went to go use the ski this past weekend and it was very slow starting like a very low battery. I stopped trying to start it and go off it. Then hit the button again and just heard the starter spinning. I took off the front cover tonight to see if the bendix gear was stuck and not popping out to connect to the flywheel.
To my amazement I saw it was popping out and spinning the flywheel but only the outer part of the flywheel was spinning with the gears. The two center hubs werent spinning. I can hand turn the center part and fell the resistance from the pistons moving. Is there a key os something that connects the outer part(gear) of the flywheel to the center two parts? Or did the flywheel just seperate? It doesnt wobble or anything.
I looked in my repair manual and doesnt go into any detail on the flywheel just how to remove it. Anyone have any insight?
