coolant hose diagram
  • coolant hose diagram
    can any one help.
    i am rebuilding a polaris sl 650 and am not 100% sure where all the coolant hoses go and if when running can i attach a water hose to one of the coolant hoses to run the engine longer
    a wee diagram would be helpful thanks
    s guthrie
    you really need to get a service manual to show you the collant routing. Unfortunatly I cannot publish this information because of copyrights.
      thanks anyway but if when i have the engine running can i connect a hose and run water with the engine running. what hose do iconnect up to?
      s guthrie
        you would want to connect it to the intake line from the jet pump
          Go to the site below and look at the parts blow up of the cooling system for your model
          year
          http://www.partsland.com/
            thanks every thing i want to know is there
            problem solved yer sum man
            stuarty from scotland
            s guthrie
