I have a 94' sl650. I am wondering what is involved in switching it over to a 750. I know the 650 and 750 both use the same crank case and essentially only differ in pistons, heads, and cylinders. My question is, is it possible to convert to a 750 by simply replacing those three things? Is the stroke length the same? and are the carbs on the 650 adequate for the 750. Is the timing the same and all that jazz? Is it even worth doing?
I will be rebuilding the engine this spring anyway and need to replace a cylinder and the pistons. For more power I wouldn't mind replacing all three cylinders and getting 750 pistons.
