Results 1 to 4 of 4
Thread: 1999 SLTX
    Feb 2003
    lincolnton, ga
    58
    Post
    I have a 1999 SLTS that will start. I have checked the compression and all cyl. are the same. It is firing and getting fuel. I pulled the plug on top of the mag. housing and put #1 cyl. at tdc and mark on the flywheel was at 0. Any HELP!
    21,545
    Post
    what is the compression you are getting? Make sure your carbs are rich enough as well.
    Jun 2002
    Charlotte NC
    1,868
    Post
    I just went threw this with the same ski.
    It had great comprission,fuel was ok and it would spark.
    I ended up getting the updated ignition kit and it fired right up. It comes with a cdi, stator and instructions $300.00.
    This may be your problem if everything else checks out first.
    May 2004
    BRICK, NJ
    13
    Post
    Have to agree with dank. You may have spark enough to start but not enough to sustain the engine running. I reccomend an ignition update kit. I've worked on at least a dozen with your symptoms that needed the kit.
  1. 1999 Polaris 1050 Throttle lever
    By jimmy the jet in forum Polaris
    Last Post: 07-31-2007, 03:22 PM
  2. 1996 sltx questions
    By mastercyberjedi in forum Polaris
    Last Post: 07-21-2007, 04:54 PM
  3. Replies: 5
    Last Post: 08-13-2005, 12:08 AM
  4. 1999 GSX Rectifier \ Stator
    By hamp1954 in forum Sea-Doo
    Last Post: 07-06-2005, 05:12 PM
  5. FS/Trade 1999 Yamaha R6 in PA
    By douglee25 in forum PWC's For Sale
    Last Post: 06-27-2005, 08:23 AM
