I saw Ocean Pro copper head gaskets that are .030" thick. What advantage is this? Do you guy recommend the use of them?
'94 SL750 - Ocean Pro Copper Head Gaskets
Copper gaskets seal better than fiber or composite, and are usually reuseable. There are companies doing custom cut gaskets, it's a race application thing.SBT Tech Support is here to help with your problems.
I don't recall what the stock thickness is. If that's over stock, it could be users on decked cylinders, or a shaved head I suppose.SBT Tech Support is here to help with your problems.
They made those hd gaskets in varying thicknesses to adjust compression on the OP heads<a href="http://www.wetwolf.com/" target="_new"><img src="http://www.wetwolf.com/images/hurrsigpic.gif" width="400" height="100"></a><br /><br />Bruce Wolford<br />Wet Wolf Technologies - Purveyor of Performance Pump Parts<br />(509) 280-5444<br /><a href="http://www.wetwolf.com" target="_blank">Wet Wolf Tech</a><br /><br />PWC Race Director<br />Northwest Water Competition<br /> <a href="http://www.nwh2oracer.com/ijsba" target="_blank">http://www.nwh2oracer.com</a>
