Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Jul 2003
    Binghamton, NY
    74
    Question
    Oil pump removal with engine in hull:
    With the carbs removed, is is possible to reach down in far enough to remove the oil pump? Also, your tech page mentioned a plastic shaft that has to be pulled out with plyers. Can this be done with the engine in the hull? I don't recall a plastic shaft when I installed the engine (1996 SLT780). Is the plasic shaft hard to remove? My line of site and room to work is tight.
    Right now I'm running premix with a bad oil pump. If possible, I'd like to block it off without pulling the motor.
    Thanks!
    Jamie.
    21,545
    Post
    No I do'nt think there is enough clearance between the plate.
    May 2004
    Springfield, Oregon
    436
    Post
    along these lines, Tech #2, do you see a problem with this scenario? :
    I'm thinking if I can't get mine out (gonna give it a good try this weekend) then what if I take the supply line, and tee it to the three outlets, thereby creating a loop.
    21,545
    Post
    Then you'll burn it out, and have a nice air leak into your case eventually.
    21,545
    Post
    Jamie - please update your email address.
    May 2004
    Springfield, Oregon
    436
    Post
    Okey-doke. Get this, I measured last time out, just how much it was using, and man, to my surprise, instead of less, it was using double (20:1)
    Feb 2004
    Baytown, Texas
    59
    Post
    if the 780 is like the sl750 it is alot easier to put the block off in with the carbs removed i just done mine
  8. #8
    Apr 2004
    Tampa, FL
    155
    Post
    It is not a platsic gear it is metal and it is on a shaft. You should be able to take the pump off then pull the shaft out with needlenose pliers etc. Then put the block off plate on with the o-ring, either a new one or off of the pump. If you need pics let me know and I will post them 4 you.
  9. #9
    21,545
    Post
    The problem is the clearance, there often isn't any.
  10. #10
    Jul 2003
    Binghamton, NY
    74
    Post
    do you think this can be done with the engine in the hull? I'm sure I can get the pump out, but not sure about the gear/shaft. What if the gear/shaft is not removed?
  1. Oil Injection Pump Removal or block off
    By SangNguyen in forum Sea-Doo
    Last Post: 07-09-2006, 07:37 PM
  2. 1997 WV1100: Shoe Horning Engine into Hull
    By tnlegendracer in forum Yamaha
    Last Post: 05-05-2006, 01:06 PM
  3. Engine pump alignment 720 140mm pump
    By cdstall in forum Sea-Doo
    Last Post: 06-05-2005, 09:26 PM
  4. 95 xp oil pump removal
    By kiwiguy40 in forum Sea-Doo
    Last Post: 02-19-2005, 07:31 PM
