"95 SLX 780
  • "95 SLX 780
    Just finished break in on SBT short block and can only get 5k on the water.On land it runs fine, but the only time I can get it over that rpm is when I'm coming out of the water over chop. It'll rev upand blast away, then wont go over 5k. It also seems to not have any"pull" when accelerating . Plugs are right on, and driveline is to spec. I did a comp. test and found it lower than I'd like; 110,105,98,I then did a wet comp test and the readings increased. Are the rings not seated, or do I have larger problem? Love the ski, but not if I can only get 38 mph's out of her.
    Those readings, if accurate, are lower than spec. Please call in and ask for Bryan, I need to get some more info from you and check some specs.
