Hey guys, I just recently bought a '00 polaris 750 and on the first trip to the lake it ran fine for about an hour. Then it wouldn't start with the push button. I could start it by jumping the solenoid. I loaded it up and come home.The next morning I hit the buton and it started right up. To get to the point, I bought another solenoid and it cranked fine for the first 20 or so starts. Then it started the same thing over, intermittantly. I nstalled a push button that would jump the solenoid and that worked for a couple of times. Then I lost spark. I did find that if I disconnected the battery cable and reinstalled it it would crank and run one time. What's my problem, I know from reading in this site you guys know what your talking about. Please help.
'00 polaris intermittant start
Re: '00 polaris intermittant start
Make sure all of your connections such as the negative cable to the block is good and not loose. If you do not find a problem then I would assume you have a problem in the cdi box. You should get a shop manual to diagnose the cdi.SBT Tech Support is here to help with your problems.
Originally posted by Technical SupportYou should get a shop manual to diagnose the cdi.
If anybody knows different, please let me know, because I have a 95 Polaris SLT 750 with an intermittent spark problem that I'd like to know the $269 CDI module will fix it BEFORE I buy it. By process of elimination, I'm down to either the CDI or possibly the stator (or both). Although ohm tests seem to indicate the stator is OK per specs in the service manual.
