Need rings for motor
  • Need rings for motor
    Hi,
    I need to put new rings on and need a little help of where i should get them. I have a 900zxi. 2 pistons have a "c" and one piston has a "b". how should I order these rings?? Does anyone have a part number?? SHould I get after market rings?? thanks for the help....Peter :D
    Are you sure you just need rings? What is the piston to cylinder clearance? What made you think you needed rings in the first place? It's very important that you have the correct clearance. If you don't have the correct clearance, then you need to go the next oversize. How many hours do you have on the pistons you are reusing? If you go to www.buyakawasaki.com they will have the part #. :D
    [ February 28, 2001: Message edited by: Bryan Glynn - SBT Webmaster ]
