Hi, I have taken my 900zxi apart and had a couple of questions. The #1 piston has a "b" on it and the other two have a "c". From what i was told, the "b" means that the pistons is one size bigger then the "a" piston and the "c" is one size bigger then the "b". The question is how much more could the cylinders go. If i need to have the cylinders worked on will there be enough material??? I hope this makes a little sense. Thanks for the help
Peter Speranza.....Peterspuds@aol.com :D
