I got a lot of water in the engine compartment and as I got it close to shore I unknowingly sucked up a lot of sand into the cooling system. After getting the water out of the compartment, I rode the ski and it over-heated! I went back to shore and took it home and flushed the cooling system. Now when I ride my ski it averages about 8 mph less at top end and is sluggish with acceleration. Full throttle rpms 7300 idles fine! Haven't checked compression. Any ideas what I need to do?
2000 900 STX loss of top speed!
You damaged your pump passing rocks and sand though it! Take it apart and send all the damaged parts to Dave at www.impros.com
Thanks for the info. I took the pump off and found a cracked and bent impeller that I could not see by an external inspection. I spoke with the people at Impros and found them to be very helpful. I ordered an impeller from them and installed it. I took it out last week and it ran better than when I bought it.
Thanks for this great forum. [img]smile.gif[/img]
