I have a 1988 kawasaki 650SX with an engine out of a 1991 X2. the engine is the same thing except for the carb, it has a 38mm CDKII, but that’s not related to my question at all. My question is this: the pump has 3 fittings on it, one for bilge, and two for pushing water to the engine. I know that a stock pump only has 2 fittings, one bilge and one to go to the cooling, but this one is “blueprinted”(or so I was told) so it has 2 cooling fitting. Now, on the hull there are three water lines that run from the engine compartment to the pump, one if for the bilge and the other two are for cooling I think. One goes from the pump to the bottom of the exhaust manifold, I know that one is supposed to be there, but it’s the other one that im curious about. The exhaust is a stock exhaust (or so I was told) it has a water fitting on the bottom of first silver pipe (the one that connects with rubber couplers on both sides and its not the cone it’s the one closer to the manifold) I would assume that this fitting should run to that second fitting on the pump, but im not sure if that would be too much water. How is it supposed to run stock? Does the hose just attach the pipe to the pipe that runs through the hull then out the back with no hook up to the pump? Or is it supposed to be hooked to that fitting on the pump. Im a little nervous that the exhaust will get too much water if I do that. Also, is there a way I can tune it to get the most power out of it?
Thanks,
Ryan
http://www.justbuytickets.com
Thanks,
Ryan
