Results 1 to 5 of 5
    Jun 2003
    MO
    3
    Question
    Since I 've never been in an engine beyond a head gasket, I'm going to ask you guys.
    I bought a 94 750 SSXI (real cheap) that was supposed to have an exhaust leak. I have had the exhaust off from the head all the way back. Nothing looked odd, cleaned up the gaskets and re-torqued to specs. It has a slight rumble, but there is still smoke in the compartment. Looks like it may be coming from the front of the engine. I also noticed some oil on the bottom of the hull.
    My question, will exhaust smoke leak by the crank seal? And will crank seals from a 650 work on a 750? Just curious since I have seals for a 650.
    [ June 19, 2003, 07:58 AM: Message edited by: Jax ]
    21,552
    Post
    If you see ANY smoke form the block itself, it needs to be torn down and rebuilt - if the seal is shot that means an air leak, and probably engine damage - you may need a new block. No the seals are not interchangeable.
    Jun 2003
    MO
    3
    Post
    If there was engine damage as you've stated, would it still run good? It runs excellent, just getting the smoke and I can't tell for sure where it is coming from.
    21,552
    Post
    it depends on the size of the leak and where it is - it may run well for a while, or it may seaize shortly - I can't say without having it. Find the leak.
    May 2006
    NJ
    1
    Default Re: 750 SSXI Exhaust Leak?
    Is there a Drain Plug on the Right Side facing front of the Water Box? I start my ski and Water and fumes come pouring out into the hull. Please help........
  1. Jet pump from a 750 ssxi to a 750 sxi?
    By bigbanker in forum Kawasaki
    Last Post: 04-28-2006, 01:33 PM
  2. 750 SSXI Exhaust Gasket
    By gp1200x in forum Kawasaki
    Last Post: 09-06-2005, 06:26 AM
  3. 94 750 Super Sport XI Exhaust Leak
    By porsch964 in forum Kawasaki
    Last Post: 08-04-2004, 09:23 PM
  4. Exhaust leak....or??
    By ColdFusion in forum Kawasaki
    Last Post: 03-02-2004, 06:24 PM
  5. 94 XP EXHAUST LEAK
    By bonne76 in forum Sea-Doo
    Last Post: 06-09-2003, 10:46 AM
