Results 1 to 3 of 3
    Jul 2002
    State College, PA
    207
    Post
    OK, the 1-year warranty is about to run out on the SBT engine and I'm thinking about getting my spare head cut down to increase compression.
    1) Does anyone know who could you this work for me (Aqua Sports, Group K, WCM, PPG)?
    2) Would any additional work be involved (rejetting carbs, etc.)?
    3) Do I use a stock gasket with the cut head or something else?
    4) Should I change plugs to BR9ES's?
    5) What sort of performance gains am I going to see?
    6) Any additional concerns I should be aware of?
    Thanks in advance,
    Craig
    21,545
    Post
    www.watercraftmagic.com can either do it or recommend someone good for Kawi.
    No carb work is needed for increased compression.
    Plugs may need to be changed, it depends ont he head design.
    Stock gaskets work unless the new design uses an o-ring.
    Performance gains are better low end grunt.
    You will need to use premium+ all the time.
    Jul 2002
    State College, PA
    207
    Post
    Thanks, tech support.
    Bill, if you read this, please let me know if you can cut this head for me.
    Thanks,
    Craig
  1. 750 ZXI high performance impeller shaft
    By jsp in forum Kawasaki
    Last Post: 07-20-2004, 10:35 PM
  2. 750 ZXI Piston Replacement Questions
    By cbeastwood in forum Kawasaki
    Last Post: 03-24-2004, 09:38 AM
  3. 750 ZXI High Compression Head
    Last Post: 08-26-2003, 10:51 AM
  4. 750 ZXI Head Cutting Questions...
    Last Post: 05-29-2003, 07:13 PM
  5. 750 zxi oil pump block-off questions
    Last Post: 12-27-2002, 01:47 PM
