can anyone tell me how to install a primer kit for a 650 sx with an aftermarket carb - mikuni type(i think i spelled it right??)
how to install primer kit 650 sx
Remove the carb from the ski.
Remove the choke plate and shaft.
The kit will have fittings to epoxy where the shaft went through.
Remove the choke knob and linkage. Drill the hull larger if needed and install the primer plunger.
Plumb into the Reserve fuel line just above the fuel tank to feed the primer and connect it's line to the carb.SBT Tech Support is here to help with your problems.
