I have a 900zxi that is oil injected, since I've gotten it I've been running it with a mix...what problems could this create....or is it probably blocked off or my 50:1 mix wouldn't let it run at all....(runs perfect, no porblems, great revving, doesn't foul plugs)
problems running oil mix w/ oil injection
Sorry man, it's Friday nite - better things to do [img]/graemlins/winkanim.gif[/img]
Anyway, don't run double oil - block off your pump or stop-pre-mixing - long term you will glaze your cylinders.SBT Tech Support is here to help with your problems.
