Does SBT stock the originals for Seadoo and other makes or another gasket brand? Which brand gaskets should we trust? TIA
Does SBT stock genuine Seadoo engine gaskets?
Re: Does SBT stock genuine Seadoo engine gaskets?
We use and sell our own, SBT gaskets. They are produced by the same factories that have contracts with other manufacturers. There is no magic in OEM parts except the markup.Last edited by Technical Support; 02-16-2005, 09:12 AM.SBT Tech Support is here to help with your problems.
the only gasket i would say to go with OEM is the 951 pipe gasket { unless the SBT gasket has the same sealing as OEM . other then that SBT gaskets are finePRIDE IN SERVICE<br /> <img src="http://www.sbtontheweb.com/images/forposts/4609/1.jpg" alt=" - " />
Yes we have the same sealing - two different 951 carbed and 1 o-ring for the pipe joint.SBT Tech Support is here to help with your problems.
