I have a 97 xp with an SBT block with 16 hrs on it. The stock prop is on there (16/23) and I am thinking of replacing it. It has an 85/88 nozzle and a new wear ring, but I have had cavitation on takeoff ever since I added a Rossier ECWI pipe and R+D rec head. It has been doing the cavitation thing since before the new engine as well, since the mods. (even on the old engine)
Even with the new wear ring, the outer edge seems a bit more than it should be between the edge of the prop and the ring. The most RPM it ever can turn is 6730-6750, but I get near 60 mph average on GPS. I ride where it's smooth water for the most part and want to spin slightly more rpms to get my pipe up into the range where it makes a little more power. I expected more rpms with this setup and flame arrestors, carbs rejetted, chokes removed, new rotary valve, etc. The old one did the same thing..low rpms. Shouldn't I get 6900-ish?
The low end takeoff is fine (as soon as it "hits" and the cavitation stops) so I'm looking for mainly more speed on the top end. The pump is sealed and double sealed again, but it still does it, and the prop looks in perfect shape and I'm careful never to run in shallow or suck anything in there so the cavitation remains a mystery.
Hoping the prop can help out, what would anyone recommend for a replacement? I do realize different brands measure them differently to each other and to the stock pitch, but what I want is a bit more on top and to hopefully ged rid of the cavitation.
If I go less pitch, in theory, won't that allow more rpms, which could mean more top end speed,(or break even) even though the pitch is less? (and also aid in reducing the cavitation)?
Any recommendations would be appreciated.
Solas X1(?)
[ February 12, 2002, 06:55 PM: Message edited by: ScreaminXP ]
Solas X1(?)
