Greetings,
I have a question. In a highly modified racing engine, what difference would it make using a 147 vs a 159 rotary valve. Timing them both the same 65 degrees closing. Does one make more torque and one make more top end power? I have the 159 in this engine now, timed at 65 closing, and it revs up and over 7800rpm, making great power, but the low end throttle response is not as good as I had hoped. It is not in the carbs, as the carbs are very sensitive to adjustments, and I would say I have them very close.
thanks
thanks
