i ran my 96xp hard today in a race against a honda i was turning about 7100 rpms and my boat started to bog real bad to where i had full throttle and it just went about 1mph came to shore and found out that rubber hose that goes from the waterbox to the back burned a hole in it, my boat is considered a limited mod, my rossier pipe had a brass mikuni jet in the stinger about a 150 size and i had a jetworks valve running to the stinger, with 3.5psi to the valve, i took off the hose to find out that the through hull fitting also melted and needs replacing, i took the hose off the stinger and the jet fell out, i just put the hose back on the stinger tower without a jet in it for now, i guess i wasn't getting enough water in the water box to begin with? it's a TDR waterbox also if that matters
i was wondering if i could get a radiator hose that's about the same size and work with that, that frickin hose is 35.97?
