you once told me a formula of how many turns out of the high speed adj =so many up on the main jet? does that make sense? in other words, say you turn your high speed adj out one turn, if you want to turn it in like sea doo carbs, how much more would you have to raise the high speed jet?
and a 1.5n/s, does it flow the max of "what" on the carb? the manual says there is no need to go bigger than a 1.5 except to achieve correct pop off. what exactly is it your flowing? is it the max the fuel pump can pump or the carb can handle, or what?
thanks................
